Faulty GPS
Hi.
I have some problems with GPS accuracy on my Enduro. It was set to GPS+GLONASS by default and after sw update it started misbehave. While running my cadence was constant (same song at 180 bpm) but my pace varied from 5:25 min/km to 7:10 min/km. I switched to GPS + Galileo and first couple of days everything was fine. Then the same thing started to happen. Power mode is set to normal. SW version is 16.70. Screenshot attached is from todays run (GPS +Galileo). Is there any way to fix this?
  • There are 3 things you can try:
    1) Powering your Enduro Off for a few seconds and then On again.
    2) Hard Reset: Hold down your top left power button until it shuts off then let go of the button once powered off.
    3) Reset: Perform a reset through the System > Reset menu.
    If the Pace/GPS issue continues with every run when there is a clear line of sight to the sky, please reach out to your regional Outdoor Product Support.
  • There are multiple treads about inconsistent pace on Fenix 6. Why would it be any different on Enduro. Both GPS hardware and GPS software are the same between the two models.
