Since I updated to 17.20, the activities are not automatically updated via wi-fi when I finish at home. If I run the sync manually via wi-fi or BT, then it works. I wonder if you have similar problems or is it just me?
I am sorry to hear you are having trouble with this. For WiFi, I would recommend trying the following steps:
It still does not automatically sync over wi-fi. Synchronisation is only possible via wi-fi manually. It used to be that I just walked through the front door and it automatically synchronised…
iam also faicng the same issue screen show version 28.15 when pairing with bluetooth
Wi-Fi Network Requirements
Supported Frequency: 2.4 GHz
Security: Unencrypted, WPA, and WPA2
Password Length: 8 characters minimum3
NOTE: Hidden networks are not compatible
In my experience manual wifi sync sometimes pop up message "wifi sync failed" but this is false cause the sync works correctly.
1. I have done a hard reset.
2. Wi-fi is 2.4 GHz.
3. Security is WPA2.
4. Password is longer than 8 characters.
5. The network is not hidden.
6. Wireless is version 28.15.
It still does not automatically sync over wi-fi. Synchronisation is only possible via wi-fi manually. It used to be that I just walked through the front door and it automatically synchronised. Now nothing happens.
I am sorry to hear this is still not working. For this, I will reach out to you via Private Message, so we can investigate this further.
