I'm referring to raster custom maps and not IMG vectors, do they work?
Thank you
Thank you
I'll answer myself: I bought enduro 2.
kmz maps work perfectly!
Hi,
how did you do this or where can I get some to test?
KMZ is just a jpeg imagem embedded.
It can be a scanned map a satellite image or any other kind of geo image.
One kmz file can have several jpeg images of a given size (device limited)
This is for Fenix 5x:
240 x 240 pixels
I rather use .img files instead because you can create your own maps based on tracks and waypoints.
Create a map using imgfromgpx:
Garmin Tutorial - how to use imgfromgpx - part 1
Create a gpx file with all tracks that you want
Open imgfromgpx
Drag and drop that file to it
Rename de gmapsupp to "xxxxx"
Copy the file to the Garmin folder on you gps
Adjust zoom and details levels on the gps
Custom map
Regards
with: Google Earth:
https://support.garmin.com/it-IT/?faq=cVuMqGHWaM7wTFWMkPNLN9
Puoi anche creare KMZ con Global Mapper, ma ci sono altri programmi gratuiti che lo consentono.
Ci sono anche editori di mappe cartacee che vendono kmz digitali pronti all'uso
Kmz and openmtb map
