Can I have the enduro calculate my Vo2max during treadmill activities? It is basically never changing. Is there any kind of setting that it also works indoor
You cannot. Here is more information from our Support Center that will be helpful understanding VO2 Max abilities:
You can. If you use a footpod and set pace and distance to come from the footpod, then you the standard Run mode on the treadmill allowing the watch to temporarily get a GPS signal. Having HR, pace and distance and from an 'outdoor' activity type VO2 will be calculated.
Please note - this workaround will not be a reliable means to acquire VO2 Max indoors.
