Double tap with one finger is for Zoom in
how to zoom out with fingers?
Hey, in the current set-up looks like you can only tap the 'minus/zoom out' icon shown on the edge of the map (or use buttons).
Thank you, i know the -/+ on the screen.
but i also tried to tap with two fingers or other intuitive gesturers, bit could not zoom out - thats the reason, why i was asking for a trick, i might not know until know.
You might enable "Touch" for the activity that uses the mapping function.
Click start > select an activity with map function enabled > long press menu > select the settings for the activity you selected > scroll down for touch > select on
It is already selected
hand how to zoom out (i am not talking about the +- Button)
At the moment looks like there is no way to zoom out with fingers (apart from the minus button on the screen) - Garmin may need to implement some sort of a software change to allow for pinch to zoom out.
