Hello Descent X50i users,
We are now 100% live with this update.
Change Log
[In-dive Change] Fixed silent diving not actually being silent.
[In-dive Change] Improved compass to highlight the lubber line in green or red when within 2 degrees of the set heading or reciprocal.
[In-dive Change] Depth units are now hidden when depth is over 100 (m/ft) to improve readability.
Added support for the S1 SubWave Buoy.
Added ability to opt in or out of Messaging and Location Sharing when pairing transmitters or buoys. Adjust this at any time from the SubWave Features menu.
Added a warning that will occur if the device reboots due to water detection within 45 seconds of being powered down. Dry the charging pins on the back and try again to ensure the device fully shuts down.
Improved the behavior of the touch panel.
Improved ease of back swipes by increasing the width of the start area on the left side of the screen.
Improved S1 pairing stability.
Tapping the device no longer turns on the backlight automatically on the surface. Pressing the touch screen (if enabled) or buttons will continue to do so.
The default backlight timeout on the surface has been reduced to 15s to conserve battery. This only applies to new or reset devices.
Fixed SubWave Features > Messaging toggle not fully disabling messaging when turned off.
Fixed an issue where starting the computer underwater (i.e. using water detection) could lead to overly conservative deco plans.
Fixed an issue when sending Dive Time SubWave messages with times over 4hrs.
Fixed constantly receiving the low transmitter battery alert when visiting the Dive Setup >Transmitters menu while a transmitter's battery is critically low.
