Hi,
I would like to find the exit points I dive before to mark up the points...
The entry and exit location I dont know how to convert it to latitude longitude??
Thanks.
Hi,
Thanks.
On the watch:
From the Dive Log widget, Select a dive, then press the "start" button to open the side menu.
Select "Save Location" and choose either the Entry or Exit Location.
Press the down button to edit, the select "Position"
The Lat Lon will be displayed.
You can also find them displayed in your dive log on the Garmin Connect site.
Open your dive activity in Garmin Connect and it should display the Entry Location and Exit Location fields. Those are in decimal degrees. If you want to convert those into the usual GPS coordinates format (degrees and decimal minutes) then you can just search for an online converter, or do the math yourself with a calculator.
