Software Update 10.10
Descent Customers,
We released the following updates.
Descent Software 10.10
Change Log
IN-DIVE CHANGE: Changed the behavior of dive compass Set to Recip., Set to 90L, and Set to 90R to set the new heading offset from the original heading instead of the current heading.
IN-DIVE CHANGE: Added the ability to hold BACK to return to the first dive screen.
IN-DIVE CHANGE: Added “Bail-out to Diluent” option if no open-circuit cases are set up in a CCR dive.
IN-DIVE CHANGE: Fixed an issue where, in a CCR dive, the PO2 was being incorrectly calculated as the maximum of the diluent's PO2 or the current setpoint. This error could occur when diving in a situation where a diluent flush would actually raise the PO2 of the loop.
IN-DIVE CHANGE: In the CCR app, the current PO2 value will now blink yellow if the diluent PO2 is below 0.18.
Added a setting to enable the UP key while in-dive (Dive Setup > UP Key).
Added the ability to set an initial surface interval when computing NDL in the Plan Dive app.
Added Fenix 5X improvements from software version 13.30 to 19.10 - www8.garmin.com/.../download_details.jsp
Increased the maximum number of apps from 40 to 60.
Improved the power-on check page to give more useful information.
Fixed an issue where changing the tap-to-scroll setting wouldn't take effect if changed from a dive pre-check.
Fixed an issue where setting up the device by pairing with Connect wouldn't respect the Connect account's metric/statute setting.
Fixed showing the Save Waypoint menu for non-dive activities.
Fixed the depth graph's x-axis to include surface time - this is most obvious on Apnea activities.
Fixed showing bad data in the Dive Log for Apnea dives when trued up from Connect.
Fixed an issue where the device was displaying incorrect time for Brazil within the Alternate Time Zones widget.
Brought in CIQ security updates.
Only addition with 10.20 - Fixed display issue with disclaimer text
Descent Mk1 Display 2.50
Change Log
Updated for new version of CIQ
Descent Mk1 Sensor Hub 6.70 (No Change log)
