Solar charging not working
Every once in a while the solar charging stops working. When I restart the watch, it works again for a while.
Here is a video showing it:
https://drive.google.com/file/d/1w32SB3Mm1QRq7coVhYHjll-ISEAmCMoW/view?usp=sharing
Since then I noticed 2 updates in the last few days, was wondering if that is a known bug that was fixed in the latest release. Where can I find the release notes of latest 11.26 firmware?
  • This update seems to only concern Asian models and being in Europe, we therefore do not have this version.
    The contents of the release are as follows:
    Latest Version2023-10-16。
    Version : 11.26 New!
    1. *23.09 sensor hub update.
    2. * Update MCMC e-label
    3. Update Descent G1 Ocean model name display
    4. General stability improvements
    5. [In-dive Change] Fixed issue with the 4th configured depth alert would not use the appropriate vibe/tone/display settings
    6. [In-dive Change] Fix last deco stop depth display when the “Last Deco Stop” setting is set to 4.5 meters
    7. [In-dive Change] Apnea dives will now automatically end within 1 second of the diver surfacing instead of 5 seconds of the diver surfacing
    8. Fixed issues with Dive Alert preview functionality Fixed issues with Apnea Surface Interval Alert’s sound and vibe settings
    9. Fixed MOD calculations on dive pre-check page not immediately reflecting water density changes
    10. Fixed issue related to adding Dive Data screens from Dive App
    11. Brought Descent G1 up to date with Instinct2 version 11.18:
    12. Added the Grade Adjusted Pace data field that displays your average pace adjusted by the steepness of the terrain
    13. Added running power data to activities without the need for a running dynamics accessory
    14. Added the backcountry snowboard activity to the list of available activities
    15. Added support for Sleep Mode
    16. Added support for Unified Training Status. When you specify your primary training device, your training status and training load sync across multiple devices and default to showing data from the primary training device
    17. Added Simplified Device Pairing Experience
    18. Added support for configuring activity alerts in GCM
    19. Added option to delete Strength workouts
    20. Added temperature recording activity setting
    21. Added Surf, Windsurf, and Kiteboard activities Added app-specific notification icons for the Garmin Jr. and Garmin Messenger apps
    22. Added an option to delete a copied activity from the device
    23. Added additional course point icons for new Garmin Connect course point types
    24. Added the setting for backlight behavior when a key is pressed during sleep
    25. Added ability to customize Do Not Disturb mode settings
    26. Added prompt to select activity profile when launching a workout from the Calendar glance
    27. Improved the backcountry ski and snowboard activities to automatically detect climbs, descents, and transition time
    28. Improved daily workout suggestions to help you train for events on your Garmin Connect calendar
    29. Improved the power data screens by showing heart rate in the dial
    30. Improved the delay when saving an activity
    31. Fixed issue where daily active calories total could be incorrect
    32. Fixed issue where Indoor Bike activity could start on wrong data screen
    33. Fixed distance discrepancies in Reference Point app
    34. Fixed GCT Balance data field font size
    35. Fixed issue where a random value could be displayed on the Edit Reps page
    36. Fixed sleep data uploads through Garmin Express
    37. Fixed possible crash on Edit Set page
    38. Fixed issues with compass calibration
    39. Fixed Surf waves activity summary page
    40. Fixed an issue where pausing and resuming a hunt activity could freeze the device
    41. Fixed an issue where starting a sync from the watch could cause it to get stuck on the “Transferring” message
    42. Fixed an issue where the HRV bar indicator could draw inconsistently on different pages
    43. Fixed possible crash during Pulse Ox reading
    44. Fixed track run alert number picker
    45. Fixed issue where autodetected FTP value could be incorrect
    46. Fixed issue where Personal Record alert could be displayed incorrectly
    47. Fixed auto step goal not updating
    Version : 9.28
    1. *20.05 sensor hub update.
    2. *[In-dive Change] Improved PO2 alerts to prevent repetitive nuisance alerts
    3. Added advanced Apnea alerts:
    4. *[In-dive Change] Added the Neutral Buoyancy alert that fires when reaching a customizable depth. This is defaulted on at 30 feet / 10 meters.
    5. *Added the Target Depth alert that fires when reaching a goal depth.
    6. *Added a Variometer alert that provides audible and/or vibration feedback about your ascent/descent speed.
    7. *Added the High and Low Speed alerts that fire when you’re ascending or descending outside of a set speed range.
    8. *The Surface Alert has been converted to use this new system, and is now located under Dive Setup > Apnea Alerts.
    9. *The apnea and scuba alerts have been split into separate menus under Dive Setup.
    10. Added Big Numbers mode for the Single- and Multi-gas dive modes:
    11. *Big numbers mode offers a simplified dive screen experience with larger fonts.
    12. *Enable this feature by toggling on Single-Gas Settings > Big Numbers or Multi-Gas Settings > Big Numbers
    13. *All dive alerts can now be set to trigger once or on an interval, and can be configured to fire only while ascending, descending, or both.
    14. *Added the ability to preview what a dive alert will look and sound like.
    15. *Added the Reference Point app and power control. Reference Point provides simple bearing and distance information to saved locations and your previous dive’s entry and exit locations (if available).
    16. *Added the Ascent Rate gauge as an option on the customizable in-dive screens.
    17. *Added the Ascent Rate field as an option to the gas/gauge dives that shows the current ascent or descent rate in ft./min. or m./min.
    18. *Improved display of surface interval times to max out everywhere at 999 days.
    19. *Updated "Deco PO2" to "MOD/Deco PO2" to help clarify what that setting affects.
    20. *Surface pressure will now be reset automatically if the watch is still in a dive when it’s connected to a computer. (Holding Up during power-on still works too.)
    21. *Improved the lag that could happen when first leaving the watch face after a while.
    22. *Pulled in changes from Instinct 2 from version 8.64 through version 9.27. This includes Pickleball and *Padel profiles, Training Status 2.0, Strength app improvements, heart rate variability (HRV) status, and many bug fixes and stability improvements.
    23. *CHN timezone map update
  • I think it's same issue as instinct 2. I'll check if it's still the case now after the latest update, if yes will return it.
    forums.garmin.com/.../instinct-2---solar-charge-not-working-after-usb-charge
