Garmin has released version 2.60 for the D2 Air series. The list of changes are below.
Changes made from version 2.50 to 2.60:
- Navigation improvements for multi-point flight plans from Garmin Pilot
- Fix Aviation Database update to not change saved METAR locations
- Fix to show Waypoint widget without Bluetooth connection
- Fix potential crash while connected to USB
- Fix METAR/WPT widget lag after reboot
- Fix METAR widget for single direction runways
- Fix to show Vertical Visibility on watch face complication
- Fix missing freezing rain bitmap on watch face
- Improvements for WiFi aviation database upgrade procedure
- Fix Aviation Units menu to refresh correctly
- Fix to show pressure units in Altitude menu
- Fix Auto Fly text units for metric/statute
- Increase minimum timed activity alert to 5 seconds
- Fix potential settings mismatch for manual flight timer operation
- Add text for mm Hg on ME TAR widget
- Fixed an issue that caused devices to reset on power up
- Added details page to last sport widgets
- Added improvements for faster syncs with Garmin Connect Mobile
- Improved shortcut setup and interaction with the page
- Fixed potential auto activity start false positives
- Fixed issues with double swipes from the watch face
- Removed golf course list timeout when starting golf activity
- Fixed layout of the 'No Notifications' page
- Added support for calibrating elevation from Garmin Connect Mobile
- Updated stopwatch layout
- Improved time to first GPS fix in certain conditions
- Made general bug fixes for golf activities
- Fixed body battery graph layout
- Increased precision of weight in strength activities
- Enabled app encryption for widgets and data fields
- Improved translations
Unlike the other D2 series devices, there is no Updates & Downloads page links.
