D2 Delta - version 6.00
Garmin has released version 6.00 for the D2 Delta series. From Garmin's "Updates & Downloads" pages for the various D2 Delta devices (see below for individual links), the consolidated list of changes are below; where a feature only applies to a specific device it is so identified.
Changes made from version 5.40 to 6.00:
  • Remove SpO2 data from .FIT file from Fly activities for increased privacy until data can be exposed in Garmin Connect.
  • Fixed an issue with downloading heart rate data post activity.
  • Fixed an issue where playlists with Cyrillic characters would not display correctly on device.
  • Fixed an issue with Powerbeats Pro audio control.
  • Fixed an issue where turn direction labels could be intermittently blank while navigating.
  • Brought in CIQ security updates.
  • Added support for updating HRM Dual.
  • Added support for connecting to a shifting sensor (Sram Etap or Di2 bike) that supports up to 4 front and 12 rear gears.
  • Fixed an issue where steps were not being counted during a multisport activity.
  • Fixed a couple of altimeter calibration issues. This should address speed spikes in activities with 3d speed enabled. (For example: Ski.)
  • Fixed an issue where the watch may freeze during a Ski activity.
  • Fixed a couple of issues which should improve device stability.
  • Fixed an issue where the device would always display the 'Updating' spinner when changing an alarm.
  • Made several WiFi related improvements.
  • Made improvements to the music experience.
  • Improved error handling when using the Garmin Pay Wallet.
  • Improve Wi-Fi sync connection stability.
  • Added support for ClimbPro 'Climb Detection' setting in Cycling. (Bike > Activity Settings > ClimbPro > Climb Detection) This allows the customer to customize grade 'sensitivity' when identifying climbs.
  • Improved ClimbPro for cycling by adding category coloring to the ascent graph, which better depicts the difficult portions of the climb. This will also be available when reviewing the elevation plot for a course.
  • Added support for uploading golf scorecard and ephemeris files over Wi-Fi.
  • Fixed an issue where the device could register a speed spike during Ski activities.
  • Fixed an issue where long activity names could be truncated in some languages after upload.
  • Fixed an issue with proximity pairing a dual mode sensor.
  • Fixed an issue with treadmill calibration.
  • Fixed an intermittent issue where the device may crash while loading maps after powerup.
  • Brought in improvements for CIQ media apps.
  • Fixed Wi-Fi 0200 Error when syncing Spotify.
  • Fixed an issue where the device would appear to be frozen when the user tries to access wallet on the device immediately after deleting wallet in the Garmin Connect Mobile App.
  • Fixed an issue where the device might crash when calculating a route for activity type ATV/Off Road.
  • Fixed an issue where the device might intermittently fail to calculate round trip routes.
  • Made improvements topairing experience with Garmin Dual ANT+/BLE Sensor
  • Made improvements to music apps.
  • Made improvements to Golf.
Changelog links:
Delta: "Updates & Downloads"
Delta S: "Updates & Downloads"
Delta PX: "Updates & Downloads"
  • I continue to maintain a list of bugs, requests, fixes and workarounds. I personally have a D2 Delta device but I am unable to contribute to the list for anything that specifically/only affects the Delta S or the Delta PX.
    I've bolded anything that would generally consider to be a serious issue that impedes use of the watch or included functionality (ie. reboots versus display or other issues). Reply below with comments and I'll keep the list updated.
    Outstanding issues / bugs:
    • [WATCH] Altimeter hardware does not seem to properly handle rapid elevation changes, either from lag or hanging (also affects Fenix 5X+)
    • [WATCH] Running Dynamics drops out around two minute mark when phone is connected; workaround: disable connection to phone while running (also affects Fenix 5X+)
    • [WATCH] There is no way to clear the tail number (aircraft registration) once entered into the watch config
    • [WATCH] sunrise/sunset calculations appear to be incorrect
    • [APPS] HSI data screen is missing from the FLY app
    • [GPS] cannot receive a GPS fix within the flight deck of an Airbus A-320 (and several other aircraft)
    • [WIDGETS] METAR widget uses watch setting for METAR visibility -- add configuration option for "visibility" to "Aviation Units" section
    • [WIDGETS] METAR widget displays blanks screen if station (nearest or manually entered) does not have a published METAR (eg. CYCZ)
    • [WIDGETS] METAR widget does not display the numeric value for the TAF visibility, and instead shows "P SM" or "SM" without the number
    • [WIDGETS] METAR widget does not handle one-way runways properly when displaying runway wind information
    • [WIDGETS] METAR widget does not calculate the runway headwind/crosswind components properly (runway magnetic heading is used with METAR wind, which is true heading)
    • [WIDGETS] Temperature widget does not display the proper density altitude when using metric units on the watch
    • [CONNEXT] Garmin Pilot does not receive the altitude from the watch
    Feature requests:
    • [WATCH] don't display the Nav Data status at the end of the "About" section, but instead display it after firmware version numbers
    • [WATCH] add configuration option for "visibility" to "Aviation Units" section, to allow selection of SM, meters or kilometers
    • [WATCH] add configuration option for "pressure" to "Aviation Units" section, to allow selection of inHG or mb
    • [WIDGETS] METAR widget only displays cloud coverage (sky) information when there is a measured ceiling but should display FEW and SCT when no ceiling is present
    • [WIDGETS] METAR widget "Use Nearest" function should retrieve an active GPS fix rather than using the last known position
    • [WIDGETS] METAR widget only displays the first six (6) periods of the TAF, which I believe is a holdover from the memory issues on the older D2 Bravo devices
    Fixed issues:
    • [WATCH] add support for Galileo GNSS
    • [WATCH] add support for Spotify (feature request, added in FW 4.50)
    • [WATCH] pop-up first-time help/hint bubbles are displayed after every reboot and/or sync [fixed in 5.40]
    • [WIDGETS] Altimeter widget ignores the widget configuration for display units of "feet" when general watch config is set to metric [fixed in 5.40]
    Old issues [could not be confirmed or appear to work as expected]:
    • none at this time
  • Since update to 6.00 my akku drain increased dramaticly and doubled to 0.648 does anybody know how to fix it. Or do you know how to downgrade to 5.6
