Constant bluetooth disconnection on Android 14 Beta
My Pixel 7 Pro updated to the latest Android 14 Beta a couple of days ago. Ever since, my Fenix 6 Pro can't hold a connection to it.
It connects ok, syncs, but then 10 mins later I get a notification on my phone that the watch wants to connect again, enter passcode, reconnect. Cycle continues like this...
Anyone else with this issue?
  • Not for me so far with Pixel 7 Pro running Android 14 QPR1 Beta1 (U1B1.230908.003).
    Have you tried a reset of Bluetooth on the Pixel? (Settings > System > Reset Options > Reset Bluetooth and Wi-Fi)
  • Thanks. That's the same version. Will try the reset and see how it goes
  • No joy unfortunately. It seems to hold connection ok when the watch is in range of the phone, but whenever it goes out of range and then comes back in, it goes through the whole reconnection process.
    Thanks anyway. Very strange!
  • For the Connect app do you have battery usage set to Unrestricted? (Settings > Apps > See All n Apps > Connect > App Battery Usage)
    Unrestricted should rule out the OS disrupting the connection to save battery.
  • Long story short: don't install android beta versions, they are always full of bugs.
  • Yeah it's set to unrestricted. Maybe it's telling me it's time to upgrade to the Fenix 7/Epix 2...
  • To be fair this is the first one I've encountered in a while. Appreciate it's a risk I'm taking though, was just trying to see if anyone else had the issue
  • It seems to hold connection ok when the watch is in range of the phone, but whenever it goes out of range and then comes back in, it goes through the whole reconnection process.
    When the watch comes back in range of the phone, is the Connect app behaving as though the watch has never been connected to it before? Or is the connection prompt coming from Android?
    There do seem to be some Bluetooth connection issues that some users experience with the f6 series that don't affect other Garmin devices connected to the same phone.
    The f6X I have periodically refuses, for no apparent reason that I discover, to sync over Bluetooth. (Wi-Fi works fine so not a server or corrupt data issue.) The f6X shows as connected and the BLE data updates (steps, real time heart rate, etc) but syncing accrued data and activities does not happen, even when manually initiated. Meanwhile the f5+ and Forerunner 735XT connected to the same phone sync normally.
    I can usually get my f6X to start syncing again by force stopping the Connect app (Settings > Apps > See All n Apps > Connect > Force Stop) and clearing the cache (Settings > Apps > See All n Apps > Connect > Storage and Cache > Clear Cache). When I open the Connect app my f6X syncs normally again.
  • That's what I get when the watch comes back into range of the phone. When I tap it it asks for the long code that appears on the watch, then reconnects, until I go out of range again Weary
    Seems like I'm alone with this issue so might be worth doing a reset of the watch and reinstalling Connect.
    Thanks again for you help Thumbsup
  • You're not alone. This behaviour has been reported before. It is one of those that pops up occasionally such as:
    https://forums.garmin.com/outdoor-recreation/outdoor-recreation/f/fenix-6-series/279510/my-fenix-6-pro-goes-to-pairing-mode-everytime-it-disconnects-from-my-phone
    It is from two years ago though.
    What firmware version is your f6X running? My f6X is running 26.00 (c7a16d5).
