Fenix 6 Series - 20.30 Public Release
Hello Fenix 6 customers,
20.30 is our public release that will be rolled out in phases starting this afternoon. We’ve posted it here for our forum users who wish to install it immediately.
Thank you to our beta testing community for your continued persistence in reporting issues observed with altimeter performance.  We know the issues have been numerous and are grateful for your feedback and continued effort to resolve specific use case problems.  We believe we’ve improved all known bugs with the altimeter performance.  However, we do see feedback on a few issues that mainly pertain to auto-calibrating to a higher value overnight or upon first calibration under certain conditions.  We believe these issues are related to bad calibration points that have occurred across the various beta updates.  If you are experiencing excessive elevation spikes or drops, please follow the guidance below to resolve this issue:
  • If the change occurs overnight, please manually calibrate to your correct elevation directly before you go to bed. (This step is important.  Calibrating in the morning will not resolve the issue)
  • If the change occurs during an activity, please manually calibrate to the correct elevation just before pressing the start button at your given location.
Thank you again to all who’ve helped improve this feature.  We understand the process can be challenging, but certainly value your input.
Please ensure that you are downloading the correct beta software for your specific device.
Instructions for installation are available below the change log on each of the above pages.
20.30 Change Log Notes (if updating from last public release candidate, v20.20):
  • Improved altitude calibration.
20.30 Full Release Change Log (Since v19.20):
  • Added ability to turn off recording an activity during a golf round.
  • Added an alert to notify user when battery is critically low during a music sync.
  • Added HRV Support from chest strap for Yoga and breathwork.
  • Added pop-up to Pulse Ox Measuring feature if the device detects too much movement and cannot get an accurate measurement.
  • Added support for new biking activity profiles: eBike, eMTB, Cyclocross, Gravel Bike, Bike Commute, Bike Tour, and Road Bike.
  • Added support for the HIIT activity profile and workouts.
  • Added support for the Pickleball profile.
  • Added support for the Padel profile.
  • Added support for the snowshoe activity profile.
  • Added support for the tennis activity profile.
  • Added new tips to indicate which activities support Incident detection.
  • Improved Explore Sync app waypoint load times.
  • Improved Lactate Threshold and Altitude Acclimation algorithms.
  • Improved measurement loading UI when taking an SpO2 measurement.
  • Update the altimeter’s auto calibration to be either be “On” or “Nightly”. Setting to “On” will set the device to periodically calibrate altitude throughout the day. Setting to “Nightly” will set the device to calibrate altitude at night and before the start of an activity.
  • Fixed issue with alarms intermittently not going off when the device is set in Max. Battery Mode.
  • Fixed display issues on the device after navigating to a point initiated by the Garmin Explore App.
  • Fixed issue where selecting a single point on a map that contained multiple items would not display the items properly.
  • Fixed issue that would corrupt open water swim activity files.
  • Fixed issue where PacePro bands would not be recognized by the device.
  • Fixed issue with activities reporting incorrect Activity Calories and Training Effect data.
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 5.30
Sensor Hub: 11.01
ANT/BLE/BT (Pro models): 6.11
ANT/BLE (non-Pro models): 3.00
Wi-Fi (Pro models only): 2.60
Please note, the beta updates released on these forums are not compatible for APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the Fenix 6 Series you have in the subject line.
We know this post states it is a public release, yet the URL states it's a beta.  This is simply a method of delivery for public beta.  We use the same channel and therefore the 'beta' term follows each of these links.  We only note it is a public release so that you are aware it's the version to go live to the public.
  • Also recieved a NDA form by mail from Garmin
    What is it for?
  • Deleted the posts about the NDA form. It was a long document with 22 headings.
  • Comes with altimeter and battery.
  • If you sign, you will get more detailed information about the new auto cal. system, but you are not allowed to talk about it?
  • Btw, the altimeter seems correct today but have not driven the car today. It seems like that causes problems for the altimeter in my watch.
  • Since the update I am not able to synchronize the music with my Deezer account.
    The watch states it needs to be connected to Garmin Connect and that any additional explanation will be presented on the phone, but there is nothing.
    So I delete the app on the watch and re-installed it via Garmin IQ, than logged into Deezer via Garmin Connect, but it still doesnt work.
    The watch is connected via Garmin Connect to my phone and the regular sync works well, just listening to music from Deezer doesnt work.
    Anyone an idea what I should try?
    Many thank.
  • Well, I can no longer take Pulse Ox readings, no matter how still I sit. Once again, Garmin screws things up with a software update....
  • За 2 месяца я так не смог добиться официального ответа от разработчиков. Просьбу вернуть ручную калибровку они просто игнорируют. Думаю все таки откатиться на 19.20. Может повезет, и гармин пей не отвалится.
  • Some other tests today. Good behaviour apparently. I went from house up hills by car this time. 44mts (garage) to 48 road and then up to 495 where I'm now. Baro changes are OK too, I travelled 80km North colder place. I've then calibrated dem at 495 and got 463mt. Then checked with smartphone app (GPStest) and got 474mt.
    Let me add the Baro alerted bad weather (see photo). Blue sky! And perfect forecast for the next 4 days.
    See you these info can help.
  • What about cadence data? They are disappeared in GarminConnect or in 20.xx watch firmware? Can't find it in both  6xPro v20.00 and 6sPro v20.30.
