Fenix 6 Series - 12.77 Public Beta
Hello Fenix 6 customers,
Please ensure that you are downloading the correct beta software for your specific device.
Fenix 6s: https://www8.garmin.com/support/download_details.jsp?id=15166
Fenix 6s Pro:
https://www8.garmin.com/support/download_details.jsp?id=15164
Fenix 6: https://www8.garmin.com/support/download_details.jsp?id=15162
Fenix 6 Pro:
https://www8.garmin.com/support/download_details.jsp?id=15160
Fenix 6x Pro: https://www8.garmin.com/support/download_details.jsp?id=15168
Instructions for installation are available below the change log on each of the above pages.
12.77 Change Log Notes:
  • Added support for sport specific power zones. One can now setup their power zones for XC Ski separately from that of Cycling. (Menu > User Profile > Power Zones)
  • Added support for displaying metrics from an indoor rowing machine that supports the ANT FE-C profile (e.g. Concept 2 with the PM5 module). This includes new fields for the Indoor
  • Rowing app: Distance, Pace, Power, and Stroke Distance.
  • Added support for an updated software update flow for ANT sensors, where the user will be prompted once they have completed the activity.
  • Added support for descriptive Varia error messages.
  • Fixed an issue with Sail Race tack assist. (MARQ Captain and Quatix 6 only.)
  • Fixed an issue where the device could crash when connected to a HRM Pro with an active Livetrack session and accessing Ski activity profiles.
  • Fixed an issue where certain CIQ elements could not be uninstalled via Express.
  • Fixed an issue where the Applied Ballistics app could not be launched through the controls menu while running another app. (tactix Delta AB only).
  • Fixed an issue where the device may fail to load a considerably long activity through the history menu.
  • Fixed an issue with setting up elevation alerts at higher elevations.
  • Fixed an issue in the paring flow where the device could return to the "Pair with Phone?" page instead of moving forward.
  • Fixed an issue where customers with high resting heart rate would intermittently not accrue intensity minutes.
  • Fixed an issue where the device was not recording position data when racing against a downloaded course.
  • Improved the reliability of ephemeris downloads.
  • Improved the presentation of information for alarms and timers.
  • Improved the scaling of lines when zooming in/out on the map.
  • Made several code improvements for Sleep.
  • Made several code improvements for Indoor Climb.
  • Made several code improvements for daily suggested workouts.
  • Made several improvements for Livetrack.
  • Updated the Applied Ballistics bullet database to version 1215 (tactix Delta AB only).
  • Resolved an issue impacting updates to features like VO2 max and Training Status.
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 5.00
Sensor Hub: 8.00
ANT/BLE/BT (Pro models): 6.11
ANT/BLE (non-Pro models): 2.11
Wi-Fi (Pro models only): 2.60
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the Fenix 6 Series you have in the subject line.
  • Hi everyone,
    I apologize that this item was not included in our original change log. Beta version 12.77 does contain a fix for the issue where VO2 Max and Training Status were not updating. I have added this note to the change log above, and on the software download links. You should no longer see this issue after installing the 12.77 beta. We are aiming to release a public update in a few days which will also include these fixes.
    Thanks,
    Mel S
    Garmin Outdoor Software Quality Team
  • Hello and thank you for the updated info. Does this fix also improve the OHR reading too high by 10/20 BPM? I'd love to drop the chest HR strap on my next LA runs :)
  • Saving pool swim activity still crashes the watch.  When it do synch afterwards the activity shows as 'Multisport'.
    (I reported this on 11.75 already with files etc mailed in, but alas)
  • When checking the stress widget, the yesterday value is very low. This happens since I've updated. If I check tomorrow, the value for Monday appear correct and the value for Tuesday is low. Every time you check the yesterday value is bottomed and correct a day after. No big deal but should be fixed
    0 Former Member in reply to Andrei
    I thought that was your HR at first!!!
  • Having the same bug!!
  • Sorry that you and one or two others are having this problem. I haven’t used mine in a pool for a few weeks now but never had a problem saving swims with and without drills. I’m mostly sea swimming now butt wo friends are still recording and saving pool swims with there F6s and F6X respectively. Both swam just the other day. As usual does not appear to be effecting everyone so hard to fix individual problems. I assume you’ve contacted Garmin beta team as requested above.
    I never knew that screen was there!  After checking it, I can confirm the same bug:
    HTH
