Fenix 6 Series - 11.75 Public Beta
Hello Fenix 6 customers,
Please ensure that you are downloading the correct beta software for your specific device.
Fenix 6s: https://www8.garmin.com/support/download_details.jsp?id=15166
Fenix 6s Pro:
https://www8.garmin.com/support/download_details.jsp?id=15164
Fenix 6: https://www8.garmin.com/support/download_details.jsp?id=15162
Fenix 6 Pro:
https://www8.garmin.com/support/download_details.jsp?id=15160
Fenix 6x Pro: https://www8.garmin.com/support/download_details.jsp?id=15168
Instructions for installation are available below the change log on each of the above pages.
Edit 9/28: we are aware of a crash that can occur when trying to manually connect to sensors, if the automatic connection fails. We are working on a fix for this issue. We apologize for the inconvenience.
11.75 Change Log Notes:
  • Added support for Daily Suggested Workouts, which are recommended based on previous activities. One can disable this from activity settings. (Run/Bike > Menu > Training > Workouts > Today's Suggestion.)
  • Added support for the Track Run activity, which allows one to record outdoor track data including distance in meters and lap splits on a standard shape 400m track.
  • Added support for Improved Recovery Time, which takes users stress, sleep, relaxation and physical activity in consideration.
  • Added support for configuring non-zero power averaging for Biking activities. (Activity Settings > Power Averaging)
  • Added support for configuring backlight settings during the sleep window. (Settings > System > Backlight > During Sleep.)
  • Added support for training and breathwork workout categories to properly handle launching workouts from calendar view and prompting yoga, strength, cardio, breathing, and pilates workouts.
  • Added Training Status explanation tip in the Training Status widget.
  • Added support for displaying the map scale when panning/zooming the map.
  • Updated the Clocks list layout and icons.
  • Improved the pairing experience for Bike lights/radar.
  • Improved compass smoothness.
  • Improved the poor wrist HR detection which will lead to more accurate VO2 Max and Performance Condition estimates. (Requires 8.00 Sensor Hub)
  • Fixed an issue where the ‘Navigation’ hotkey was not working as expected for certain use cases.
  • Fixed an issue with the wind speed field on watch face.
  • Fixed an issue where open water swim activities were capturing an erroneous position in the track log.
  • Fixed an issue where the device would fail to load the elevation plot when navigating to a POI.
  • Fixed an issue where the elevation plot would intermittently get doubled while navigating.
  • Fixed an issue where expired weather data was being displayed on the watchface.
  • Fixed potential GPS communication problems. (Requires GPS v4.60)
Current beta peripheral software version numbers below. New versions are indicated in red.
GPS: 4.60
Sensor Hub: 8.00
ANT/BLE/BT (Pro models): 6.06
ANT/BLE (non-Pro models): 2.11
Wi-Fi (Pro models only): 2.60
Please note, the beta updates released on these forums are not suitable for APAC region devices.
Please send all bug reports to [email protected], and indicate which model of the Fenix 6 Series you have in the subject line.
  • 24/7 HR is good until you reach more than 130, for me it never go beyond 130...  for most part of the day is good enough.
  • still the OHR is useless for me. Up to 50 bpm difference
  • My respiration is also working.
    And, not to comment-crap, but technically, you can get respiration without a "HR strap". I use a Polar OH-1 optical sensor (which, the more I think about it may actually count as a "strap") and respiration works with that, and my data with it seems to make sense.
    Which means there must be some other reason Garmin doesn't allow respiration with the WHR.
  • And, not to comment-crap, but technically, you can get respiration without a "HR strap". I use a Polar OH-1 optical sensor (which, the more I think about it may actually count as a "strap") and respiration works with that, and my data with it seems to make sense.
    I tried to choose my words carefully and not to say "*chest* strap".
    I don't know what data Garmin uses to determine respiration, but I assume it is HRV, and a heavy watch bumping about on the wrist is probably not accurate enough. Heck, if WHR is imperfect at best then I think it is more of a reach to expect sensible WHRV data under the stress of exercise.
    On a more stable body part (forearm/upper arm) with less weight to the measuring service I imagine the data quality would improve.
  • That's promising they can get to the end of that bit as well. My Wife has tachycardia and uses hers for a health device. She says for her the only problem so far is if she takes the watch off (to charge) it takes a little longer to lock back on to her.... Promising though!
  • I have "struggeled" with GPS accuracy with regard to track-distance since I bought the F6Pro in december 2019, and I have tested all GPS-versions, all betas.
    It is not accurate in difficult conditions, i.e. trail-running in my deep forest on "my" route, very high trees.
    With the GPS 4.60 there is no improvment at all. It still shows 9.67km on my 10.00 km trailrun-track. It have always done that, and I suspect it will always do, until F7 (with the new Sony-chip which when released in 2021 will consume 50% more battery if it is set on very high accuracy).
    With GPS 4.60 in open landscape it still is excellent on track distance, and have always been, since december 2019.
  • Having bluetooth issues when listening to music on my runs after updating to this beta, (turns on and off at random) also cant adjust the volume, any of you fine people know a fix for this?
  • You can only measure heart rate variation (HRV) if you can measure the electrical signal from the heart and identify the R-R interval, hence why a chest strap is going to be the most accurate method. Using optical heart rate the watch/armband is trying to detect the peak in what is effectively a sinusoidal colour change under the skin caused by each pulse of blood; this is pulse wave variation (PWV). The terms are used interchangeably by many but in reality are two very different things. One is a direct measurement of electrical activity (HRV) the other an estimate of the electrical activity derived from the interpretation of a colour change (PWV). it makes sense for GARMIN to stop trying to detect respiration and stress and pulse ox during exercise due to the difficulty in detecting the peak-to-peak variation in pulse rate as the watch is moving around considerably more, amongst other things. This is essentially the same reason why you need to be still to measure pulse ox and stress.
    During non-activity periods and of course during sleep, it is easier to estimate respiration and stress from PWV using optical sensing.
    0 Former Member in reply to 6441091
    Yes. Use the 6x pro version
