Stuck with blue triangle on Garmin Explore
Hi,
I've got a blue triangle with my name on it in the middle of Africa. I've tried logging in / out and syncing the device but I can't get rid of it. Any ideas?
Cheers.
  • Can you attach a screenshot so we can get a better idea? It sounds like you may have started tracking without a satellite fix (which might happen if you're indoors) and the location defaulted to what you're seeing on the map. When you start tracking outdoors with a clear view of the sky, do you see your correct location reflected on the map of the Explore Website?
