Holes are in incorrect order or wrong.
When I installed Golf app on phone, holes were correct. Now the holes are either in the wrong order or are a different course. Tried reinstalling golf app and, again, holes were correct at first but then change after I close out of the app. Hole order remain correct on the watch. Only issue is in phone app.
  • Every time you open the Golf APP on your smart phone and use the "Start New Round" option to manually keep score, the APP searches your nearby courses using your smartphone's location services and then your nearest courses pull up with a note of their distance away from you.
    If each time you open the Golf APP and select the same course, you see the course holes as wrongly represented, please take screenshots of the issue as you come across it and contact Golf Product Support. We will be happy to assist you further.
