Acknowledged
CIQQA-3357
Battery drain after app exit caused by ActivityRecording API
I have noticed behavior that the GPS gets turned on when I start an ActivityRecording session, without me needing to enable GPS events with
Position.enableLocationEvents(Position.LOCATION_CONTINUOUS, method( :onPosition ));
When inspecting the FIT file after recording it is full of all the gps information, and when vieing the activity in the Connect app all the location data is as I would expect from an app utilizing GPS. I am using SPORT_RUNNING with a sub sport. I can't find anything in the documentation around whether this is expected or not. This seems reasonable to me and I am fine with this behavior.
The reason I bring this up is I have gotten reports, and have noticed myself, that there are battery drain issues after the app is closed. I have seen the other threads on this topic and have made sure to close the sensors, disable gps events, and close and null out the session and timers.
I clean up the Session as described in the documentation:
session.stop();
session.save();
session = null;
Yet the issue persists.
I have created an alternative version of my app where I don't use the Activity Recording and instead enable/disable the Sensors and GPS directly and I don't see the battery issue.
This leads me to believe there is an issue in the ActivityRecording API that turns on GPS/Sensors for its own use, but does not clean them up appropriately. Resulting in the battery drain.
I have primarily tested on FR955 but have gotten reports of it on Venu3S as well. I know one other person with FR245 and they claim not to be seeing the issue.
Given these API Versions: FR245 => 3.3, FR 955 + venu3s => 5.1, The issue might be localized to a later ConnectIQ API version.
Parents
  • Another reproduction, on a Forerunner 265 - and two assumptions in this thread ruled out on that device.
    I maintain a padel scorekeeper device app on the Connect IQ store. A user reported ~25% overnight drain (about 2.5%/h, roughly 10x his normal) after playing, with the watch face showing and the app exited normally. The visible symptom is the optical HR LED staying solid after the app closes. Device: Forerunner 265, firmware 29.05 (beta), Android phone.
    Rather than guess, I built a guided diagnostics device app and had him run it. Each step records one 60-second ActivityRecording session, exits, and he looks at the back of the watch about 30 seconds later and answers ON/OFF at the next open. Steps that need it start from a watch restart. The recording path is exactly this, nothing else in it:
    var s = ActivityRecording.createSession({
    :sport => Activity.SPORT_RACKET, :subSport => Activity.SUB_SPORT_PADEL, :name => "..."
    s.start();
    // 60 s
    s.stop();
    s.save(); // or s.discard()
    System.exit();
    Run 1 (broad, 8 steps). ON = LED solid after the app closed.
    - padel session (RACKET/PADEL), saved, exit -> ON. One 60-second session from a fresh restart is enough; it does not take a long activity.
    - Position.enableLocationEvents(LOCATION_CONTINUOUS, cb) then LOCATION_DISABLE on the leaked watch, exit -> ON (does not clear it).
    - Sensor.setEnabledSensors([]) + Sensor.enableSensorEvents(null) on the leaked watch, exit -> ON (does not clear it).
    - a second, scratch GENERIC session, start()/stop()/discard() in one call, exit -> OFF (cleared), once.
    - re-leak -> ON; the same scratch again -> ON. So 1 of 2.
    - GENERIC/GENERIC session instead of RACKET/PADEL, saved, from a fresh restart -> ON.
    - padel session discarded instead of saved, from a fresh restart -> ON.
    Run 2 (narrow, next day). Same watch, same firmware.
    - leak run -> ON.
    - scratch GENERIC session held open 5 seconds before stop(), then discard(), then exit -> ON, three times in a row. 0 of 3.
    A watch restart clears it every time, as everyone else in this thread reports.
    What that rules out on this device:
    1. Not sport-dependent. GENERIC/GENERIC leaks exactly like RACKET/PADEL. The thread's working assumption is that the bug depends on the Sport/SubSport; on the FR265 it does not.
    2. Not the saving. A discarded session leaks the same as a saved one - it is the session itself that leaves the state behind.
    3. Not fixable from inside the app. Releasing location events and sensors before exit changes nothing, and re-entering and leaving recording clears it only by coincidence: 1 of 5 attempts across both runs, and 0 of 3 when the second session was given time to actually run.
    Brandon asked earlier in this thread for a PRG that reproduces it. I have one: the diagnostics app above is on the Connect IQ store as "PU Diagnostics", and I can attach the PRG plus the relevant source here or send it wherever is convenient - it is a small app whose only job is this test.
    A second user, on a Forerunner 255, is running the same test now, and I will post his rows here. If it matters for triage: this FR265 is on beta firmware 29.05, which is why I want the second device on public firmware before anyone concludes it is a beta-only regression.
    In the meantime the only advice I can give my users is to restart the watch after playing, and my store listing carries a note about it.
Comment
    s.start();
    // 60 s
    s.stop();
    System.exit();
    - leak run -> ON.
Children
  • Some thoughts:
    - Most of the thread hints it's a GPS thing, your test hints it's a HR thing.
    - If the assumption is that it's a GPS thing, then it would make sense to test it with an Indoor Walk or Indoor something activity, that doesn't turn GPS on. I don't think the activity type is what matters, but if different activity types turn on different hardware, then it might make a difference.
    - At least in your case there's a visible way to see that there's a problem, unlike when the GPS stays on
