makeWebRequest in background after an OAuth
Hello there,
In my DataField app I've maid an OAuth which gives me a token. So now I want to download a json so I've that
using Toybox.Background as Bg;
using Toybox.Application as App;
using Toybox.System as Sys;
using Toybox.Time as Tm;
using Toybox.Communications as Comm;
// The Service Delegate is the main entry point for background processes
// our onTemporalEvent() method will get run each time our periodic event
// is triggered by the system.
const ClientId = "";
const ClientSecret = "";
const ApiUrl = "";
const RedirectUri = "https://localhost/";
(:background)
class JsonBackground extends Toybox.System.ServiceDelegate {
	(:background_method)
	function initialize() {
		Sys.ServiceDelegate.initialize();
		Comm.registerForOAuthMessages(method(:accessCodeResult));
    function onTemporalEvent() {
      	System.println("onTemporalEvent2");
            go();
    function go() {
        Sys.println("go");
        Comm.makeOAuthRequest(
            // URL for the authorization URL
            // POST parameters
		//...params///
            // Redirect URL
            // Response type
            Comm.OAUTH_RESULT_TYPE_URL,
            // Value to look for
            {"code"=>"value"}
    // Handle converting the authorization code to the access token
    // @param value Content of JSON resp	onse
    function accessCodeResult(response) {
        Sys.println("accessCodeResult " +response.data );
        if( response.data != null) {
            Sys.println("accessCodeResult Ok");
            getJson(response.data["value"]);
        else {
            Sys.println("Error in accessCodeResult");
    function handleAccessResponse(responseCode, data) {
        Sys.println("handleAccessResponse");
        if( data != null) {
        	Sys.println("data handleAccessResponse OK");
        } else {
            Sys.println("Error in handleAccessResponse"+responseCode);
        Bg.exit(data);
    function getJson(accessCode) {
        Sys.println("getJson " + accessCode);
        var url = "https://jsonplaceholder.typicode.com/posts/1";
       	var params = {};
   	    var options = {                                             // set the options
           :method => Comm.HTTP_REQUEST_METHOD_GET,      // set HTTP method
           :headers => {
            	"Content-Type" => Communications.REQUEST_CONTENT_TYPE_JSON
  	       :responseType => Comm.HTTP_RESPONSE_CONTENT_TYPE_JSON
       	var responseCallback = self.method(:handleAccessResponse);
        Comm.makeWebRequest(url, params, options,responseCallback);
and that
using Toybox.Background;
using Toybox.WatchUi as Ui;
using Toybox.Time;
using Toybox.UserProfile;
using Toybox.PersistedContent;
using Toybox.System;
(:background)
class KronosApp extends App.AppBase {
	var inBackground=false;
	var bg=null;
        AppBase.initialize();
		Sys.println("AppBase initialize");
    	if(Toybox.System has :ServiceDelegate) {
    		Background.registerForTemporalEvent(new Time.Duration(5 * 60));
    	} else {
    		Sys.println("****background not available on this device****");
   		Background.registerForOAuthResponseEvent();
    // onStart() is called on application start up
    function onStart(state) {
	    System.println("start");
    // onStop() is called when your application is exiting
    function onStop(state) {
    	if(!inBackground) {
    		Background.deleteTemporalEvent();
    		System.println("stop");
    //! Return the initial view of your application here
    function getInitialView() {
    	System.println("getInitialView");
    	var Kview = new KronosView();
        return [ Kview];
    //store json data in bgdata
    function onBackgroundData(data) {
		System.println("onbg "+ data);
    function getServiceDelegate(){
    	inBackground=true;
    	System.println("getServiceDelegate");
        return [new JsonBackground()];
In the console when I run the app in the simulator I've that:
Background: AppBase initialize
Background: start
Background: getServiceDelegate
Background: start
Background: onTemporalEvent2
Background: go
AppBase initialize
start
getInitialView
Background: start
Background: accessCodeResult {value=>4b90b6dabf72e29c3f07e84340bb1e34f0d0edf3}
Background: accessCodeResult Ok
Background: getJson 4b90b6dabf72e29c3f07e84340bb1e34f0d0edf3
So as you can see handleAccessResponse is not called, I've seen other threads about this but it doesn't work for me.
